Author Topic: How to keep cold air intake from getting wet during the rain season?  (Read 7902 times)
blacky1.8T
So i have cold air intake on my car for a while and have been enjoying it. It is reaching down behind the bumper breathing cold air and it makes good noise. Now my concern is, during the long rainy season in Vancouver, it will get wet for sure. Is there any way to prevent it from getting wet? Or should I just forget about having a cold air intake. Suggestions please. :(
Jim Rock
  • The Ace of Spades!
don't drive with your hood open.
Bust out the champagne and condoms!
RONDAL
  • Smurf Tamer
unless you plan on submerging your car and the intake and hitting WOT in the process you will be fine.
TEAM HIGHSCHOOL
I find intelligence inhibits my ability to enjoy dubberz.  It's like playing chess at a go-fish tournament
Moofluffen
  • Road Warrior
You'll be fine.
Just avoid deep water on the intake side of the car, but like Rondal suggested, you really don't need to worry unless you plan on submerging the car. You could always just take it off for the winter if you're really concerned.
I have a K&N filter bag over my air filter to block out a little more water.
« Last Edit: Sep 02, 08, 07:56 by Moofluffen »
88Clipper
Great investment! Plus it will double the life of your filter.  :thumbup:
Maxvw
  • Glorified Dumpster
the only problem i had with my scirocco's CAI was when it was snowing and the filter turned into a snowball
Put in the time, not the effort?
Almost too low to dyno
Got Warts
  • I shat in the hat
Get an AEM bypass valve, that will catch any water going through your intake.
They are like $50 at Lordco.
I lasted 31 seconds.
RONDAL
  • Smurf Tamer
TEAM HIGHSCHOOL
jettag60v2
Relyk
  • up clowse
blacky1.8T
Thanks guys. So looks like as long as i don't drive into a pond i will be fine. But doesn't the filter get splashed with water since its so close to the ground and effect its performance?
dexterrorist
  • loud guns and sharp knives
if you're using a k&n (of something similar), the oil in the filter should repel the small amount of splashes that get up there. just avoid really, really deep puddles and/or lakes.
RONDAL
  • Smurf Tamer
The only thing you may want to do is clean your filter a little more often and make sure its properly oiled.  DO NOT OVER OIL IT THO!!!
TEAM HIGHSCHOOL
been there, done that.... down one turbo
ckone
Fuck me…. People still buy cold air intakes? :wall: What the fuck for? Seriously, unless you plan on dragging a ¼ mile against another car, might I suggest jus going with a panel filter in a regular air box?
If you do happen to own a 1.8T Golf, then having a CAI is going to do nothing for you. If you really want cold air charge, then put a big assed intercooler on your car. Putting a CAI without an inter-cooler is like putting a rubber on after you jacked off on the girlfriends ass….
I am the sites Red Foreman - Dumbass
"You wagon guys are always confident in fitting things in your car" - Germanstyle
Relyk
  • up clowse
:lol: :rofl: sig'd
RONDAL
  • Smurf Tamer
come on...its still 2002 right?  CAI is still considered a 10whp mod...15whp IF you add the K&N sticker.
TEAM HIGHSCHOOL
ckone
If it is -15 degrees out side.....  :thumbup:
88Clipper
Of course. That's why they dyno test CAI's at the North Pole.
