Author Topic: FS: Mk4 taller 5th gear for gasser (from TDI)  (Read 572 times)
Nuje
« on: Oct 07, 19, 15:22 »
One of the easier mods you can make which you can enjoy and take advantage of just about every drive - myturbodiesel.com rates it as 2 out of 5 in difficulty (with changing the oil being like a 1 out of 5).
Process is here: https://www.myturbodiesel.com/wiki/5th-gear-swap-modification-mk-iv-golf-tdi-alh-02j-egr-5-speed/
This is a stock 5th gear out of an ALH TDI engine (0.756; final drive 3.389), which will lower your rpms in your 5sp. 2.0L or 1.8T (.837; final drive 4.235) at highway speeds quite nicely.
$200
« Last Edit: Oct 07, 19, 15:28 by Nuje »
Nuje
Re: FS: Mk4 taller 5th gear for gasser (from TDI)
« Reply #1 on: Nov 17, 19, 15:01 »
Sold
