Author Topic: My 87 20v Project  (Read 12511 times)
Nick_2.8L
  • '93 Corrado
My 87 20v Project
« Reply #20 on: Mar 20, 13, 07:49 »
Good stuff!
euroasian
  • Instagram: @thrillier_90
Re: My 87 20v Project
« Reply #21 on: Mar 20, 13, 09:52 »
Ill have to bring out those mount for you
---95 GTi vr6(RIP) -93 jetta 2.slow -06 lancer ralliart -01 GTi 1.8t(RIP) -95 GTi vr6(R.I.P) -98 integra gsr -93 ls400 -95 Golf Cl -07 rabbit 2.5
cdiddydo
  • Testers
« Reply #22 on: Mar 20, 13, 11:29 »
You going to revscene spring meet?
AudiFan6
  • VAC/Abby Thug
« Reply #23 on: Mar 20, 13, 12:21 »
Nice Work Colin, looking sick. Just need to get it finished now ( i mean running as its never finished)
2004 Audi B6 S4 [Oettinger Body-kit] [KW V3'S] [19X9 Bentley Continental Wheels] [Stoptech St-40] [JHM Trio Package Short Shift] [Fast Intentions 2.5 DP's] [Fast Intentions 2.5 Exhaust] [Valeo Bi-Xenon Ecode Headlights] [RS4 Pressure Plate] [JHM Stage 4 Clutch] [034 LWFW] [JHM 10mm Intake Spacers]-"Buying a used B6/7 S4 is like playing Russian roulette"
cdiddydo
  • Testers
« Reply #24 on: Apr 29, 13, 21:58 »
alrighty time for an update, now it may seem like i just did the same thing twice and thats because i did :( couldn't get one of the control arm bolts to torque down, because the welded nut was stripped. Got a new k-frame of my apparent new parts dealer john (fasthopper) and slammed it all back it!
finally got a strut mount that would work with my coils:mad:
they are mk3 vr mounts with cx racing coils, mk3 10.1 hubs with mk3 DE brakes
i also got the car back on the ground which seemed to be a big hurdle for some reason.
also took out the headliner which was all broken and hooked the column back up.
going to wash the thing tomorrow after it being stored in a barn for almost 2 years.
then out comes exhaust and tank for a re-undercoating.
William
  • Testers
« Reply #25 on: Apr 29, 13, 22:34 »
Look'n good.
'93 Si. - VTEC Purgatory
B3VR6
My 87 20v Project
« Reply #26 on: May 07, 13, 23:08 »
Keep it up
Benyameen Kawlboose
  • boots
« Reply #27 on: May 07, 13, 23:58 »
had to do a double take on those front brake callipers, because they look almost identical to standard mk1 callipers
great progress!
Wake up. Stand up. Please look at this picture. Look at this picture please.
cdiddydo
  • Testers
« Reply #28 on: Jul 20, 13, 22:55 »
here is a bit of an update, finally got to work on the bay, just trying to get it back to a point where i could spray it t-red again. not looking for show car like looks here, just plain simple tidied up etc...not all smooth and perfect.
so i filled a few spots
then i hit it with some etching primer
and then 3 coats of filler primer, which i will give a quick 400 grit sand before i hit it with some color,
flippyfloppys
« Reply #29 on: Jul 22, 13, 16:09 »
Looking great Collin, nice to see some other cars coming close to being back on the road  :thumbup:
Haunted by: 99 GTI Project
Daily: 85 Jetta coupe
Autohau5
  • Gasoline rainbow in the gutter
« Reply #30 on: Jul 22, 13, 17:19 »
The irony. :suspicious:
'01 A6 2.7TT 6MT  |  '81 Rabbit S 16VG60   |  '15 Touareg TDI R-Line   |   '96 YZF750R
cdiddydo
  • Testers
« Reply #31 on: Jul 22, 13, 20:52 »
got the bay all sprayed, did a semi gloss black, figured black is a good choice since i will bang shit up putting the motor in etc, then once the whole car gets resprayed i am going to redo the bay, more shaving etc.
also got some other bits painted
CouchSurfer
  • Testers
« Reply #32 on: Jul 23, 13, 15:23 »
Looks good!
cdiddydo
  • Testers
« Reply #33 on: Jul 23, 13, 17:53 »
Thanks for the support guys, if all guys well motor can go in soonish
Just need
Mk2 cross member + bolts
Transmission mount
Dbw gas pedal
cdiddydo
  • Testers
« Reply #34 on: Aug 12, 13, 12:28 »
alrighty! time for a pretty big update!
since my last update i have done quite a bit of important stuff. I mounted the clutch master and the brake booster etc......got the master cleaned up and put in. got the brake lines back in., cleaned up a front crossmember and put that in aswell.........also pulled the 02m clutch, mk4 a/c compressor and mk4 powersteering pump/............
so i could finally put the motor in!   anyways let the pictures do the talking
cdiddydo
  • Testers
« Reply #35 on: Aug 18, 13, 22:49 »
got some more work done,
trans all cleaned up and painted, went for this kind of hammered look which doesn't show well in the picture, clutch kit ordered. went with the xtd stage 3, been hearing some decent enough reviews
and also rotated the housing on the turbo so it will clear the hood
flippyfloppys
« Reply #36 on: Aug 27, 13, 21:00 »
wicked!
cdiddydo
  • Testers
« Reply #37 on: Aug 27, 13, 21:02 »
just waiting for the correct flywheel to get here, then motor will be on all 3 mounts for the first time since 2008. exciting stuff
Abbythug
  • Testers
« Reply #38 on: Aug 30, 13, 00:49 »
good work
i may have to swing by your place to help with cams so i can see this
You gonna be a fucking smartass in every thread you find?
        -bigdaddyroth
cdiddydo
  • Testers
« Reply #39 on: Sep 27, 13, 15:38 »
alrighty haven't updated this in a little while,
recently got a new oil pan adapter from CTS installed that,
put the rad support in and got a rough idea of the charge piping some pictures to follow!
also got my shift tower installed in the 02a transmission, need to align everything still.
currently waiting on some parts, for piping and heat shield for the firewall.....cuz turbo bro
and sound deadning for the interior! PROGRESS
