Passat b3 syncro wagon how to remove drove shaft
Started by shawnigan.smith, Dec 06, 17, 16:00
shawnigan.smith
Hey im in the middle of a clutch job on this thing. Since its syncro imi have to take off the rear driveshaft to drop the tranny. Im tunning into an issue
The guibo has 3 bolts on each side but we cant get them out. Theres not ebough clearence between the guibo and the transfer case
Whats the best way to proceed? Any tricks to getting the driveshaft out? Any help is good help
Sent from my SM-G930V using Tapatalk
Autohau5
I've never had an issue with sticking a wrench up between the subframe and removing the bolts.
'81 Rabbit S 16VG60   |  '15 Touareg TDI R-Line   |   '96 YZF750R
shawnigan.smith
Quote from: Autohau5 on Dec 06, 17, 16:13
Youve done this on a syncro? Ill try again tomorrow. Any more tips? We're  accessing it from the bay should we be doing it from beneath? Does the exhaust need to come out
geeteeexe
Autohau5
Quote from: shawnigan.smith on Dec 06, 17, 16:33
Yes, 3 times.
If you go under the car, you can just get a wrench in between the subframe and angle drive to remove the guibo bolts. You'll then have to pry the driveshaft rearwards as there is a centering hub that usually get corroded into the angle drive.
shawnigan.smith
Quote from: Autohau5 on Dec 06, 17, 19:38
Yes, 3 times.
Your a lifesaver. Id youre in vic id love to pic your brain
shawnigan.smith
Also one last thing. Do i need to drop the transfer case before i drop the trans or can i just do the trans and leave the t case attatched
Autohau5
Quote from: shawnigan.smith on Dec 06, 17, 19:51
I find it makes it so much easier to remove the trans. Remove the 4 bolts and support bracket. You're gonna lose fluid so get a pan ready.
shawnigan.smith
Still having no luck
Anyone local who can swing by and take a look?
the bartender
unbolt transfer case from tranny and prop shaft, then move it towards the passenger side (up and out of the way). Then drop the tranny like any other VW tranny. Also if the brace is on the tranny by the shift tower, remove that too.
