News: Have a safe May long weekend everyone!
Author Topic: Best offset for a 8.5" on a mk2?  (Read 722 times)
Shmee
  • VWs are a means of transportation, not speed!
« on: January 25, 2008, 04:07:10 PM »
as the title states, looking for the best offset on a MK when running an 15x8.5.
doing some basic math a, 3et would put me pretty much at factory backspacing on a 6" 35et.
now would a 15et, which would take off about 12mm of space from the strut side work better?
i've got a set of Rado steelies i'm planning on getting widened but would like the best possible fit with minimal to no poke.
also, can i run a wider wheel in the rear or a different offset to get more dish while keeping the same stance as far as poke/tuck goes?
Thanks!
ZX3TuningPower in Style
 fighting for peace is like fucking for abstinence  --  Target
Vancityvdubber
Re: Best offset for a 8.5" on a mk2?
« Reply #1 on: January 25, 2008, 07:38:06 PM »
your rear wheels are placed further inward than the front right from the factory. if you're putting 8.5's up front you're gonna poke, big time with an et of 3 or even 15. an 8 with an et of 20-25 would probably be best, then put an 8.5 or 9 in the rear with like an et 5-10.
Shmee
« Reply #2 on: February 06, 2008, 01:22:14 PM »
any other thoughts on this?
hellgti
« Reply #3 on: February 06, 2008, 05:54:43 PM »
i tested my 8" wheels.  et on them is 34 iirc.  So, they fit flush up front, and with 20mm spacer, flush out back.  stock flares.
Take care of each other out there. everyone here is my brother, let's make sure everybody goes home safe. Alright, let's stomp some heads. - Scott Vogel
Vancityvdubber
« Reply #4 on: February 07, 2008, 11:04:36 PM »
you could also drop a straight line from your fender and measure the backspace of your current wheels. add the 2 together to see how big you should go as well as et
the bartender
  • I control the horizontal, and the vertical
« Reply #5 on: February 10, 2008, 07:44:19 PM »
keep in mind that the rear wheels are offset to one side. so if you try to make them flush, one side will stick out more than the other (its usually like a 15mm difference)
hellgti
« Reply #6 on: February 11, 2008, 09:24:10 AM »
rawr, tell me about it  >:(
Shmee
« Reply #7 on: February 12, 2008, 01:09:47 PM »
interesting... so i'd need a spacer on one side to square up the fitment?
any reason for the offset?
so back to the original Question, what would be the best offset for a 8" front and 9" rear??
hellgti
« Reply #8 on: February 13, 2008, 09:49:15 AM »
assembly plant worker laziness.  who knows.  All VW are like that because of the rear beam settup.  Even my MKIV was, though not nearly as much as my MKII.
the bartender
« Reply #9 on: February 13, 2008, 11:35:28 AM »
et 10 (you will need to do some fender work though)
Shmee
« Reply #10 on: February 14, 2008, 12:43:14 AM »
et10 on the 8s and 9s?
fender work isn't a problem... i have a roller, cutoff wheel, sawzall and a Tig, i can make just about anything work!
hellgti
« Reply #11 on: February 14, 2008, 09:13:20 AM »
this is gonna be awsome  :D
SR-71
  • Top post score!
« Reply #12 on: February 14, 2008, 12:30:08 PM »
yes i noticed that too! i thought my car was crooked. why did they do that?
digby scallop
  • TH up in this bitch
« Reply #13 on: February 17, 2008, 01:16:07 PM »
well my car isnt like that   :rofl:
mind you the FRONT right wheel sticks in about 1" more than my left...maybe its been hit a couple times.  :rofl:
Nik says:
 everything was powered by grounds only
  nick_1.8t wouldnt exist if it werent for me. i'm his dad  VRT: just another $4200 penis extension  europlates are gh3y
