News: Have a safe May long weekend everyone!
Author Topic: bbs lm torque specs from bbs  (Read 2337 times)
Jakob
  • "what year is your scirroco?"
« on: March 18, 2011, 01:16:42 AM »
taking apart a set of lm's. Do they require a sealant when put back together?
« Last Edit: March 25, 2011, 12:12:26 AM by Jakob »
Mattie
  • O Sh*t!!
Re: bbs lm
« Reply #1 on: March 18, 2011, 01:22:09 AM »
what he said  :thumbup:
« Last Edit: March 18, 2011, 01:34:29 AM by Mattie »
"Doug doesn't need to have a bath. He goes fast and the dirt flies off." - Seanner
you = retard
13 seconds on 13 inches
macleanshaun
  • Dump'd + Daily'd
Re: bbs lm
« Reply #2 on: March 18, 2011, 01:26:17 AM »
LMs are a 2 piece wheel, with the barrel being one piece.
No sealant is necessary.
Just make sure you use loc-tite on those bolts when you put em back together (reverse mounted I hope)
BBS RMs are a 2 piece wheel as well, but because the lip is one piece, and the face/barrel is the 2nd piece, it splits the barrel, and needs sealant.
yvrnycracer
  • thuper
Re: bbs lm
« Reply #3 on: March 18, 2011, 01:30:15 AM »
What he said... You can also reverse mount the face to get a bit more dish ou of the barrel as well!
2007 3071R Built 2.0T Jetta GLI... gathering dust...
2010 Touareg V6 TDI
2011 S4
Jakob
Re: bbs lm
« Reply #4 on: March 18, 2011, 02:55:26 AM »
bit more poke yes. :)
« Last Edit: March 18, 2011, 03:41:18 AM by Jakob »
Jakob
Re: bbs lm
« Reply #5 on: March 18, 2011, 02:58:18 AM »
anyone here a machinist? cash in hand
Jakob
Re: bbs lm
« Reply #6 on: March 20, 2011, 02:12:40 PM »
the bolts are too short, wont work on reverse mount :-/, took it to my brothers machine shop and they don't recommend  machining the face, or mounting it on the inside. spacers it is.
« Last Edit: March 20, 2011, 04:56:49 PM by Jakob »
macleanshaun
  • Dump'd + Daily'd
Re: bbs lm
« Reply #7 on: March 20, 2011, 10:37:28 PM »
Too short?
The distance that the bolts need to be sunk is exactly the same. Shouldn't need to do any machining. Someone correct me if I'm wrong.
Jakob
Re: bbs lm
« Reply #8 on: March 20, 2011, 11:44:50 PM »
Too short?
nope, didnt have enough thread. There was also some kind of sealant/glue behind the face. Ill post pics up tomorrow.
« Last Edit: March 20, 2011, 11:47:45 PM by Jakob »
najob
  • Cthulhu this...
Re: bbs lm
« Reply #9 on: March 21, 2011, 08:08:32 AM »
Reverse mounting LMs is pretty common practice from what I've seen.
DAS. Expect nothing less.
macleanshaun
  • Dump'd + Daily'd
Re: bbs lm
« Reply #10 on: March 21, 2011, 11:31:04 AM »
Dont want to sound like a dick.... but you're simply mounting the face of the center on the other side of the barrel, not flipping the face 180 degrees around, right?
Jakob
Re: bbs lm
« Reply #11 on: March 21, 2011, 02:47:09 PM »
It works! I had the weights in the way and didnt even notice :no: Project still underway :yippie: if you hadn't posted up that picture I wouldn't have double checked. thanks!. need to find out the proper torque for bolts now.
« Last Edit: March 21, 2011, 02:48:42 PM by Jakob »
N-tilt
  • Realist.
Re: bbs lm
« Reply #12 on: March 21, 2011, 03:03:35 PM »
Mr. Maclean saves the day
'92 Gti 2.0 16v - lemon
'93 Corrado Vr
'89 325i
najob
  • Cthulhu this...
Re: bbs lm
« Reply #13 on: March 21, 2011, 06:06:18 PM »
20ish ftlbs.
« Last Edit: March 21, 2011, 06:07:53 PM by najob »
Jakob
Re: bbs lm
« Reply #14 on: March 23, 2011, 02:49:49 AM »
Send a letter to bbs for torque specs
called memory fab and they torque at 22-28 lbs..
« Last Edit: March 23, 2011, 01:24:33 PM by Jakob »
Jakob
Re: bbs lm
« Reply #15 on: March 24, 2011, 11:56:42 AM »
after hours of reading stories about wheels failing/breaking Ive decided that it would not be a good idea to change the design that bbs spent countless hours perfecting/testing for safety and reliability. They will be sent in for refinishing and proper re-assembly. screw it
« Last Edit: March 25, 2011, 12:43:03 PM by Jakob »
95rado
  • hit and run magnet
Re: bbs lm(pleaase delete)
« Reply #16 on: March 24, 2011, 03:48:59 PM »
Why delete it? The whole point of a forum is archiving information. Looking forward to seeing the finished product on the car.
if you annoy people they're not "hating". - Toffeerado
najob
  • Cthulhu this...
« Reply #17 on: March 24, 2011, 05:12:41 PM »
You aren't the first person to reverse mount LMs... or the the last for that matter.
macleanshaun
  • Dump'd + Daily'd
« Reply #18 on: March 24, 2011, 08:33:52 PM »
 :no:
Reverse mounted is the only way I would ever have LMs on a car.
There must have been some kind of background story for those that failed. There's really no reason for a wheel to fail unless there was some kind of mistake in reassembly, or previous damage to the wheel.
Either way, the wheels will look great.
Jakob
« Reply #19 on: March 25, 2011, 12:12:02 AM »
Well I was afraid I wasnt going to get a response from bbs regarding proper torques but just received an email. here you go:
19 ft. lbs. with a drop of blue Loctite.
Regards,
Michael Cox
Aftermarket Sales
BBS of America, Inc.
5320 BBS Drive
Braselton , GA 30517
Tel:  770-967-9848 ext 3027
Fax:  770-967-9866
Toll free:  800-422-7972
Email:  michael.cox@bbs-usa.com
Web:  www.bbs-usa.com
