Author Topic: Wanted; B5 A4 rear diff  (Read 1416 times)
falcon
« on: Sep 09, 18, 13:44 »
As the title states.
Re: Wanted; B5 A4 rear diff
« Reply #1 on: Sep 09, 18, 15:58 »
I have
« Reply #2 on: Sep 09, 18, 16:19 »
Year, engine, trans? There's 3 rear diffs, each with a different ratio. Getting the 3-letter code of your diff would ensure 100% compatibility.
'81 Rabbit S 16VG60   |  '15 Touareg TDI R-Line   |   '96 YZF750R
falcon
« Reply #3 on: Oct 21, 18, 14:30 »
Ok I'll take a look.  It's a 99 1.8T.  Where on the diff is it located?  Would I be able to see it with he diff still in the car.
falcon
« Reply #4 on: Nov 11, 18, 16:46 »
I found the info I need, should be DAJ coded.
« Last Edit: Nov 11, 18, 16:48 by falcon »
« Reply #5 on: Nov 11, 18, 18:18 »
DAJ is correct, part number 01H-500-040-J.
35:9 ratio. 1996-2002 cross reference.
