Author Topic: a5 3.0TDI  (Read 6082 times)
NCabbyT
  • Guest
a5 3.0TDI
« on: Oct 08, 11, 13:27 »
I want this!  In an A4 Avant...
Audi A5 3 0 TDI full exhaust
Audidoodi
Re: a5 3.0TDI
« Reply #1 on: Oct 08, 11, 13:35 »
Wow... This is dirrrrtty
1996 Audi UrS6 - The Ongoing Project (Samco Boost Hoses, VVME 4300K 35W HIDs, TFSI Coil Conversion, Apikol Diff. Mount, Apikol/Poly Rear Subframe + Rear End Bushings, HPR Motor and Trans mounts, Apikol Snub Mount, Bilstein Sports + H&R 29800s, Avid.1 AV-20 18x8.5 wheels, Conti DWS06 tires)
2017 VW Golf Sportwagen 1.8T - Family Wagen
1986 Audi Coupe GT - Tornado Red (SOLD)
eurotrash
  • lurker
Re: a5 3.0TDI
« Reply #2 on: Oct 08, 11, 13:43 »
i wish they'd bring the 3L TDI over here
2005 CTS-V
2017 Toyota Highlander | Limited | Midnight Black Metallic
NCabbyT
  • Guest
Re: a5 3.0TDI
« Reply #3 on: Oct 08, 11, 13:49 »
It only makes sense that they do.  It's already in the T-Regs and Q7s.
Jeremy Sawatzky #2
  • Hodor
Re: a5 3.0TDI
« Reply #4 on: Oct 08, 11, 14:17 »
Why is it that when its on the dyno around 4k rpm, does the black smoke come out in timed spurts???
2005 BMW 325i, 2016 Mazda CX5, 2014 KTM 1190 Adventure, 2006 Yamaha FZ6
Re: a5 3.0TDI
« Reply #5 on: Oct 08, 11, 15:46 »
I'm sure you will see it in an A6 of some sort. Probably in the A8 as well as it would be a great setup for car services etc. You definitely won't see it in any sort of smaller or sportier cars as North American's don't get that. Potential for the Q5 as well.
diesteppenfuchs
Re: a5 3.0TDI
« Reply #6 on: Oct 08, 11, 16:56 »
Problem is only the back half sounds good, in the front it's still a John Deere...
06 A3, 99 Mk3 VR, 91 e30
the end is the beginning is the end
NCabbyT
  • Guest
Re: a5 3.0TDI
« Reply #7 on: Oct 08, 11, 17:49 »
You can barely tell anymore unless you pop the hood and pull off the engine cover.  There's so much sound insulation it adds a good 100 lbs to the front of the car.  :P
diesteppenfuchs
Re: a5 3.0TDI
« Reply #8 on: Oct 08, 11, 18:47 »
It's all good. My A3 sounds like a diesel, even if it's gas... Maybe the next big thing would be soundproofing injectors.
Re: a5 3.0TDI
« Reply #9 on: Oct 08, 11, 19:56 »
sounds pretty good in the high RPM, but down low its meh.
