Author Topic: Vag-com Mods for B7  (Read 7847 times)
Vag-com Mods for B7
« on: Oct 05, 11, 13:47 »
Vag-Com Codes
Euro Headlights & DRL
 * Module 09 (Central Electrical), recode to ###XY, where:
 X = DRL
 0 Halogen without DRL
 1 Halogen with DRL
 2 Bi-Xenon with DRL
 3 Bi-Xenon without DRL
 4 Bi-Xenon with DRL / tail light / license plate light
Y = Locale
 1 Rest of World / Nordic Countries / Denmark / Croatia / Baltic Countries with Bi-Xenon
 2 Nordic Countries / Denmark / Croatia / Baltic Countries without Bi-Xenon
 3 USA / Canada with Bi-Xenon
 4 Canada without Bi-Xenon
 5 Special Vehicles
*Bonus 1* Enable Dashboard Headlight Indicator
 Module 17 (Instruments), recode to ??###, where ?? = [existing 2 digit value - 2]
NOTE - This mod tested on bi-xenon cars only; halogen cars may not work as intended.
Disable Seatbelt Chime (Still wear your seat belts, were applicable!
Module 17 (Instruments), recode to 00###Z#, where:
Z = Warning Type
 0 Disabled
 1 Europe NCAP Visual indicator always on, audio chime for 91 seconds active
 2 USA & Canada NAR Old Visual indicator & audio chime for 6 seconds at startup
 3 USA & Canada NAR New Visual indicator on, audio chime every 30 seconds
 4 Europe NCAP including front passenger seat
 5 USA & Canada NAR Old including front passenger seat
 6 USA & Canada NAR New including front passenger seat (North American B7 default)
NOTE - All Module 17 recodes can be combined and done together. e.g. To do both above, recode to ??#Z1
**Bonus 2** Trip Computer Fuel Consumption Correction Factor
 Module 17 (Instruments), Adaptation channel 03
- Affects: Instantaneous Fuel Consumption, Average Fuel Consumption, Range, & Distance to Empty
 - Default: 100%
 - Range of values: 85 115%
Remote Window Functions
 * Module 46 (Central Convienence), recode to [existing value + 64]
1-Click Unlock All Doors
 Module 46 (Central Convienence), recode to [existing value - 4]
***Bonus 3*** Disable Auto-Lock
 Module 46 (Central Convienence), recode to [existing value - 32]
NOTE - All Module 46 recodes can be combined and done together. e.g. To do all 3 above, recode to [existing value + 64 - 4 + 32]
Fixing Dip Headlights display
Headlight Adjustment
 [Select]
 [55 - Xenon Range]
 [Basic Settings - 04]
 Group 001
 [Go!]
 Activate the Basic Setting.
 [ON/OFF/Next]
The meas. block field now shows "Wait" and should switch to "Adjust Headlights" then (this may take up to 10 seconds).
 Adjust the headlights using their manual adjusting screws as referenced against a suitable aiming target.
 [ON/OFF/Next]
 The adjustment should now be learned.
 [Done, Go Back]
 Don't forget to check/clear fault codes afterwards.
 [Close Controller, Go Back - 06]
Disable TPMS
Select -> 17-Instruments -> Adaptation -> Channel 61.
« Last Edit: Oct 25, 12, 15:31 by Schmiesus »
