Author Topic: Ecu converting from automatic to manual? Help  (Read 1837 times)
maddmike
« on: Jan 22, 14, 23:33 »
Hey hoping some one out there can help me out I read it's possible to convert a ecu from a automatic to a manual but i have no experience with it and am wondering if anyone out there does? It's a chipped ecu for a 1999 aeb 1.8t Quattro auto and I need it to be for a 5 spd. If someone can point me in the right direction that would be great.
unicorn tears are the number one ingredient in black magic
83RedRoc
Re: Ecu converting from automatic to manual? Help
« Reply #2 on: Feb 28, 14, 19:16 »
Yes it is possible to do this, I just did it in fact.
You'll need to recode the ECU.  To do this you'll need Vag-Com or another VW specific cable that enables coding.  After that its quite a simple procedure to code it to a different value.
http://www.audiforums.com/forum/diy-do-yourself-55/diy-how-recode-ecu-use-your-car-181068/
SR-71
  • Top post score!
« Reply #3 on: Mar 12, 14, 10:10 »
Not all ECUs will take that programming but it's easy to try with Vag Com. Depends on the ECU revision and a the chip used.
DAS. Expect nothing.
« Reply #4 on: Mar 14, 14, 19:02 »
This. The AEBs use 512kb chips which simply don't have enough room for the second set of maps.
'81 Rabbit S 16VG60   |  '15 Touareg TDI R-Line   |   '96 YZF750R
