Author Topic: Clutchmaster Clutch Failure, Dont make the same mistake I did  (Read 8588 times)
AudiFan6
  • VAC/Abby Thug
So last year I bought a Clutchmaster FX250 clutch and had it proffesionally installed. It worked fine for about the first 12,000kms then the slipping began, I ended up running it for about another 8,000kms as I couldnt afford another Clutch/the clutch i wanted. So after 20,000kms of mediocore driving with a a solid break in period my car went back to the shop (bairly clutch was a disaster at this point) to get a new clutch.
FYI my car is a 2004 Audi S4 (JHM stage 4 clutch now).
I just thought I would vent and put this out there so someone else doesnt make the same 2K mistake I did. Check out the forums and such as there is plenty of information out there of this clutches failing quickly.
« Last Edit: May 06, 14, 19:48 by AudiFan6 »
2004 Audi B6 S4 [Oettinger Body-kit] [KW V3'S] [19X9 Bentley Continental Wheels] [Stoptech St-40] [JHM Trio Package Short Shift] [Fast Intentions 2.5 DP's] [Fast Intentions 2.5 Exhaust] [Valeo Bi-Xenon Ecode Headlights] [RS4 Pressure Plate] [JHM Stage 4 Clutch] [034 LWFW] [JHM 10mm Intake Spacers]-"Buying a used B6/7 S4 is like playing Russian roulette"
Vdub_Garage_Adrian
funny...i run a fx400 will well over 500hp to the wheels and tons of track abuse and havent had a problem yet and theres actually a few of us runnning the same set up with no problems at all
97 VRT-11.95@130.54mph
Jonnymooshoo
    • 2004 MK4 .:R32
I'm running an fx 400 and its starting to slip after 17months... Only tracked it one day last year.
AudiFan6
  • VAC/Abby Thug
Ya seems like your getting about what I got out of it.
Jozzie the Vancouver Audi Club forum creator has a FX400 set up on his A4 also. He's dealing with the same slipping issue.
The guys at PG informed me it was cause the springs seemed fatigued and clutch disk still had tons of material left. (sping fatigue @ 20,000kms is pretty redicolous)
Also the FX250 pressure plate is a Sachs, seems like they just add there own disks to it.
Just my two cents, but it sounds to me like these clutches aren't meant to be daily driven.
I have never understood why people who are basically putting down stock power put anything other than an OEM clutch there?! (stock power to me is OEM/basic bolt ons/chip)
AudiFan6
  • VAC/Abby Thug
I would agree with that on the FX400 set ups, but I was running the very mild FX250 (they must have developed that for daily use)
idk about this as I went even more hardcore on the clutch this time, but atleast it uses a OEM pressure plate.
Ya. Why didn't you just get an OEM clutch, Serg? They are more than capable for bolt on power.
'81 Rabbit S 16VG60   |  '15 Touareg TDI R-Line   |   '96 YZF750R
Gerg
Stock clutches last 150,000+km
Why go anything else? But that's coming by me who swears by F1 racing brand
'92 GTI VRT - '93.5 Corrado VR6  - '04 R32 - '01 GTI 24V
eurotrash
  • lurker
my 1.8t running apr 94, tb exhaust and bolt ons (maybe 250hp at the crank) has 300000kms on the original clutch with no slipping... stock clutches are pretty robust
2005 CTS-V
2017 Toyota Highlander | Limited | Midnight Black Metallic
AudiFan6
  • VAC/Abby Thug
Haha common you know common sense doesnt always prevail when upgrading.
The set-up I chose was the one I wanted to run all along. Pretty well the Popular choice on Audizine and Trying to make my car a full JHM bolt on car.
Ya mine at 110km was still good but just swapped it when doing chains for the clutchmasters.
cpa93
Also running an fx400 for about 10,000 km now. hoping mine will be good togo. Although I never launch it ever.
AudiFan6
  • VAC/Abby Thug
Ya man it seems like it goes one of 2 ways, either they work awesome or fail early. Hope yours lasts.
Your running it on ur daily?
« Last Edit: May 08, 14, 12:27 by AudiFan6 »
cpa93
Daily driven on a mk4. Will be turning up the boost in a month, that will be the real test.
SR-71
  • Top post score!
You have to abuse performance clutches. Mediocre driving will lead to premature failures. Performance/race clutches are meant to be driven hard.
DAS. Expect nothing.
SR-71
  • Top post score!
How exactly was this determined? If they have some sort of actual proof you can probably get some warranty from CM?
dork
  • John Player Special
    • the dub allstars
I switched to DSG. Regret nothing.
Creative Director | Dub Allstars co. / Videographer | The Box One Collective
www.theboxone.com
AudiFan6
  • VAC/Abby Thug
I have the whole set-up but like you said determining it is going to be the hard part. All i can say for sure was that it was slipping, cant for sure say why it was.
Seems like a lot of guys are running into similar problems on the Audi Platform
http://www.audizine.com/forum/showthread.php/482238-ClutchMasters-warranty-sucks!-Clutch-options
Its deffinetly quicker and more comfortable to daily.
But theres nothing like having the 3rd pedal and having to put in some effort to get it right.
« Last Edit: May 09, 14, 17:22 by AudiFan6 »
Having owned two DSG's i wouldn't buy another to daily. It's great performance wise, but the new zF 8 speed is way smoother and basically as fast.
I always chuckle at the manual "excuses" especially in the era of DSG and PDK transmissions. Manual is good fun and classic but far from practical and in reality slower and less efficient.
If I were you I would go back to the OEM setup unless you are putting a supercharger on that V8.
dork
    • the dub allstars
That sounds like something poor people say.
But in all seriousness. I used to say the same thing about Manual vs. DSG, until I actually drove a DSG for extended periods of time. It's like driving a video game. Which to me, is fun as hell. And when my hands are full texting, or drinking, or reading, I can just throw the car in D and not worry about switching gears, or having my left leg go numb from using the clutch in stop and go rush hour traffic.
Manual transmissions are fun in old cars that have throttle cables or a more raw feel to the pedals. New cars with drive by wire are almost soulless to drive. Heel/Toeing is less exciting because you can't "feel" the throttle, it's like a light switch and has no sensitivity.
Basically, this has nothing to do with the original thread.
www.theboxone.com
Blue Flame
  • OG in hiding
    • Oil For Good
:lol:
Saw you last night on 56ST in Tsawwassen, A3 looks hot.
Oil For Good
