Author Topic: B7 A4 2.0T stripped bolt  (Read 1330 times)
SmurfBlood
« on: Oct 10, 16, 15:16 »
I picked up a revision D diverter valve as mine was not holding boost. When installing, the top bolts stripped the threads in the aluminum. I was barely putting any pressure on so I am thinking they were on the way out anyways.
My questions are, what does the diverter valve bolts screw into. I just got this car so I am still becoming familiar with it. What is the best route for fixing this problem? I have had it suggested that I retread or use a longer bolt but I would like to do a genuine fix if I can.
SR-71
  • Top post score!
Re: B7 A4 2.0T stripped bolt
« Reply #1 on: Dec 06, 16, 13:46 »
It threads into the turbo.
DAS. Expect nothing.
