Author Topic: 2007 B7 FSI Stumble 2000-3000 RPM  (Read 1980 times)
superchicken
  • Chopper Togger
« on: Sep 12, 16, 09:01 »
Alright,  I've been trying to diagnose this issue for a while.
When the car is cold, it idles perfectly fine, but stumbles between 2000-3000 rpm on a part-to-mid throttle acceleration.
I have done the following, in the following order:
New HPFP in January
PCV TSB was applied
Purchased car one month ago at 159,000km:
1. Upgraded coil packs to red tops. - no change
2. Inspected NGK Platinum plugs, wear and gap appeared fine. - no change
3. Performed intake decarbon one week ago, valves were moderately coated (about 2-3mm of coating on each intake) - engine pulls harder at higher RPM, but no change in crossover
4. Replaced cam follower (was showing minor wear)
5. Replaced NGK Platinum with BKR7E Copper Plugs gapped to 0.032" at 159,500km  as per - http://www.audizine.com/forum/showthread.php/423881-B7-A4-2-0T-Spark-Plugs-Replacement-Guide-v2-0  - cold start seemed smoother at first, pulled better at higher RPM again, but overall no change.
Tune is 100% stock, engine is 100% stock (aside from copper plugs and red tops)
No CEL's present on the dash, don't have VAG-COM at the moment, but I'm suspecting changeover flaps issue?
flickr.com/iangwills
facebook.com/iangwills
Re: 2007 B7 FSI Stumble 2000-3000 RPM
« Reply #1 on: Sep 12, 16, 09:56 »
Have you changed the fuel filter on that thing?
Joker
  • Blood Spit and Tears
« Reply #2 on: Sep 12, 16, 12:13 »
N57 valve? Heard that causes a lot of small little issues and its an easy fix
.:Stage Awesome:.
« Reply #3 on: Sep 12, 16, 12:50 »
N75 you mean?
« Reply #4 on: Sep 12, 16, 12:55 »
I would expect a code
superchicken
  • Chopper Togger
« Reply #5 on: Sep 12, 16, 13:12 »
Isn't that one the PCV valve?  It was updated in January and I've confirmed it looks new.
superchicken
  • Chopper Togger
« Reply #6 on: Sep 12, 16, 13:12 »
Probably do that tonight if I can source one locally, but I would expect starvation at WOT on the top end.
« Reply #7 on: Sep 12, 16, 13:15 »
We can log it when your back down next
Sent from my LG-H831 using Tapatalk
Joker
« Reply #8 on: Sep 12, 16, 17:46 »
maybe N80 valve then
.:Stage Awesome:.
« Reply #9 on: Sep 12, 16, 18:07 »
That I could see. Ian come grab my n80 off my car. It's brand new.
